Cavie said:
Just a point of information. Smoke detector locations are not a NEC requirement and having one in the attic is not a fire code requirement at least in Florida. GFI feeding downstreem bathroom recepticals (as long as it is just recepticals) is code compliant. 2nd GFI not required but is added insurance I suppose. Or a waste of money depending on how you look at it.
This is where the NYS Residential building code takes precedence. Smokes are required in the attic, inside each bedroom, and in a hallway over ten feet. Plus one per level, and another in the boiler room. They must be interconnected. Some Towns and Villages are more restrictive on this, Requiring CO and combination detectors in homes.
What is also code is that if you have a room with two entrances like a hallway or my dining room then two three ways are required. same goes for staircases.
The GFCI issue is faulty wiring, here only one GFCI is actually required, but if you go with extra ones, you should at least wire them correctly. It makes no sense to wire a GFCI from the load side of another GFCI.
As far as the switched outlet in the bedroom. Everyone makes mistakes, but if you check your work, or your helper's work, you will catch it before the homeowner moves in. This is a really stupid thing to get a callback on.
There is also something called pride in your work and the standards of the trade. Two things that have seriously declined over the years.
Years ago I worked for a shop in Local 3, run by two of the biggest hacks around. These guys wired condos in a very tight residential market, and cut every corner in the book. They were stingy with the staples and refused to buy screws, pvc glue or anything else they could steal from other trades. Even these guys did better work than this hack. Even these guys saw the value in wiring a house that the people would like and find convenient. It was these guys that taught me to test everything in the house before you leave. The 20 minutes you spend is a lot cheaper than the callback.
As far as this being a no license county, WTF, so people shouldn't live up here? We should just put up with shoddy work? An unlicensed electrician is still an electrician and should be held to the same standard. They are doing the same work and have the same obligation to the customer as someone with a license.
I just want the guy to come back and fix his mistakes.
