spectrum24
- Tampa, FL
I have had some confliciting advice regarding the proper feeding of a transformer from 120/240 service. One camp says to ground the neutral from the service, and just use the 2 hot legs to feed the transformer, with the windings connected in series. The other camp says ground the neutral, connect the windings in series, and then connect it to the center tap of the transformer. I would appreciate input on this question. So, the question is, is a 2 wire or 3 wire connection to the transformer required?
