Proper way to crimp a butt splice?
mbrooke
Batteries Included
United States
Technician
What is the proper (technical) way to crimp a butt splice? >>>
I have always used this:
However I am being told its incorrect? :?
petersonra
Northern illinois
engineer
electricians seem to like the plier type tools because they are cheap and fast.
if not done correctly and consistently though, you can have problems which is why most engineers specify a controlled cycle crimper that makes the crimp exactly the same way every time and entirely removes the human variability that would otherwise exist.
https://www.cdw.com/shop/products/P...s_kwcid=AL!4223!3!61836302419!!!g!18283950120!
mgookin
Fort Myers, FL
A certified calibrated tool that matches the crimp connector is the "official" way to do it. You'd have to look for listed connectors and find the matching tool.
qcroanoke
Sometimes I don't know if I'm the boxer or the bag
Roanoke, VA.
Sorta retired........
If the crimp mfgr. requires a certain tool you have to use that. If not I guess as long as you can't pull it apart you're gold.
Smart $
Esteemed Member
Ohio
Listed compression-type connectors almost without fail specify one or several crimp tools, which must be used to maintain the listing.
qcroanoke
Roanoke, VA.
What I suspected, though I must ask why such a tool needs to cost $350? :eek:
Because it can....
I'll hazard a guess that they really don't sell that many and if you buy one to comply with the requirements you're gonna pay for it.
AKElectrician
Up to AHJ IMHO, been places where the name brand crimp must be crimped by the same name brand crimper, don't matter if the lug company specifies another tool that can be used, if it doesn't say the same name brand on both it's a no go. Same place makes you where ice cleats in mud if there is ice on a pond you cant walk too though...
mgookin
Fort Myers, FL
Those expensive tools are most commonly used in listed shops. The NRTL inspector wants to see it.
Regardless of what tool you use, if you damage the insulated part, you're a no-go. Part of the requirement of using listed connectors is that you don't damage the insulation.
mbrooke
Batteries Included
United States
Technician
Oddly, well crimped splices with a $40 crimper seem to hold up just fine, and for years. Sounds more like technical jiber jaber I guess.
mbrooke
Batteries Included
United States
Technician
About the only tools that I see damaging insulation are ones with points on the diye.
GoldDigger
Placerville, CA, USA
Retired PV System Designer
Just to get a vigorous discussion going: :)
Do you crimp only the thick metal barrel or do you also crimp the thin section covering the wire insulation?
GeorgeB
ElectroHydraulics engineer (retired)
Greenville SC
Retired
I've always been told that an insulated terminal is squeezed only, not indented. The ones you show, like the common Klein StaKon cutter/crimpers, are for uninsulated. The old "Service Tool II" by then AMP I think, now TE Connectivity TE Connectivity 696202-1, handled those "flag" terminals that folded over the conductor, the other "flag" that folder over the insulation, and the squeeze for the insulated "barrel" crimps.
I think I paid about $40 for mine in the late 80s when I had to make up a dozen or so multipole connectors with the flag crimps.
mbrooke
Batteries Included
United States
Technician
Do you have a link for that tool?
My understanding is that the most strippers squeeze rather than indent. Is this not the case?
Frank DuVal
Fredericksburg, VA 21 Hours from Winged Horses wi
Electrical Contractor, Electrical Engineer
mbrooke
Batteries Included
United States
Technician
GeorgeB
Greenville SC
Retired
