Pullenselectric
New member
- Oak Hill WV United States
Does a 12x12 box strictly used for pulling no splicing etc. have to be readily accessible? Code article needed! Thank you.
Readily accessible: No
Accessible: Yes
See Article 100OK, I'll bite: What's the difference between "Readily accessible" and "Accessible"?
Under A. You won't find anything but frustration if you look in the R's.See Article 100
Same as an LB. Common sense really, if you have to pull wire out or more in, you need access. (Seen enough that weren't accessible, like when they build the deck over the cover)Does a 12x12 box strictly used for pulling no splicing etc. have to be readily accessible? Code article needed! Thank you.
That is correct.Under A. You won't find anything but frustration if you look in the R's.
