Grouch1980
- New York, NY
Hi all,
I came across 3 other questions:
1. If you have a solar PV array that is ground mounted, is there a max distance that the array can be located from a house? I'm aware of losses in the wiring if the distance is too far, just curious if anything in the NEC dictates a max distance between a house and PV array.
2. With a ground mounted array, is there a limit on the max wattage size of the array? since the array is now out in the open, theoretically now you can have as many solar modules as you want, and are not limited by the roof area if installed on the roof of the house. Understood that depending on how i connect to the utility service, can limit the size (connecting to the supply side or load side). Just wondering if there was a max wattage rating.
3. I've been looking through LG and Tesla batteries... their KWH ratings don't seem to make them last very long. Are there batteries out there that can last multiple days, to provide back up power for the critical loads panel? Assuming it's a lot of cloudy days, and utility power is out.
Thanks!
Thanks!
