Energy-Miser
- Maryland
Does anyone see much interest where you are in solar or other alternative generation installation?
			Thanks for your reply. Yes I agree that for most of these technologies the payback is just too long. However, some states do have subsidies that will make some of those options more attactive. e/m.got_nailed said:If you looking at solar as an investment then your looking at the wrong thing. The payback on solar is 8 to 12 years depending on where you live and your setup. ....
Energy-Miser said:Yes I agree that for most of these technologies the payback is just too long. However, some states do have subsidies that will make some of those options more attractive. e/m.
Yes it's true in many cases. These things will of course have to be looked at from the entire product life cycle perspective, up and down stream from raw material to manufacturing to disposal of the products at the end. There is a big debate for example on how much biofuels are helping or hurting the environment. As a nation we will need to be smart about where we're heading (in terms of energy choices, use and conservation), but that's going way above my paygrade!! e/m.iwire said:Along with marketing opportunities.
In this area we are seeing very large corporations spending a lot of money on PV installations, between the tax breaks, power company incentives and the fact they can say they are "Green" company in spite of any pollutants they may be disposing of makes it worth while.
This of course forgets that making the PV cells and the batteries is very un-green.
Yes, I have looked into dealership opportunities for evacuated tube water heating systems. They make perfect sense for most areas, even work in cloudy conditions and save lots of money. I found out that you will need to have or work with a licensed plumber and probably have to fight over zealot home owner associations in most neighborhoods, but overall it could be a very lucrative business.petersonra said:the payback on solar PV just does not exist today unless someone else is subsidizing it. It is so far out that the time value of money far exceeds whatever you may or may not save on electricity.
there are a few exceptions, such as places that don't have electrical service. but for the most part, at this point in time it is a big loser, unless someone else is footing a big chunk of the bill.
ironically, low cost, and very low tech solar heating is very cost effective with no subsidies at all. But is not sexy enough I guess.
Yes Justin, I understand that Mass. is very progressive along with California, and even NJ, in our area. PA governor too has announced pretty high marks. My state (Maryland) is moving along at a steady pace in terms of support, but nothing that will say wow let's all jump into this thing !! e/m.JJWalecka said:I have read that State agencies are being more energy conservative. Compact fluorescent lamps were installed in the Governors office. ...
Justin J. Walecka
Here I know a company that does exclusively solar, not sure how they survive, but that's what they do. They deal with the solar end of it and state and federal incentives and all that, and install the panels, etc. but then have a conventional EC pull he permit and make the final connectionsJJWalecka said:I have heard that a permit to install an Alternate energy source for a business or dwelling, say a wind turbine, is expensive and timely.
I am pro alternate energy. I hope that with every small step we take will encourage it.
Justin J. Walecka
got_nailed said:With wind power it can be a tricky. How many months will the wind blow like the 2 weeks that you watched it? Will someone build something down the road that will change the direction and speed of the wind where your turbine is?
Thanks for the link. Looks like wind is making great progress in Europe (Denmark, Germany, Spain for example). Here too in Texas and California ...dduffee260 said:http://www.turby.nl/
I watched this a few weeks back on some science channel. This looks like the way wind power is headed. I don't know if the link will come up but if not then just copy and paste it. It comes up in Dutch or some other language but there is an english link at the top also.
The design I believe is called vertical axis wind turbine. They are much less common than the horizontal axis types that sit on top of very tall towers. The advantage of the vertical axis is that you don't need the tall tower, which cuts down on that expense and also makes servicing easier. Additionally, you don't need to turn your turbine into the wind for it to work (as you would with the horizontal axis style). The disadvantage of course is that down near the ground wind speed is much smaller and air flow is more turbulent compared to 300 feet up high. e/m.got_nailed said:Dduffee260
I have looked at the Turby. Yes there has been a lot of talk about ... .
If they will not let you use a heat exchanger then they will not let you use a turbine or a few PV panels.Energy-Miser said:Yes, I have looked into dealership opportunities for evacuated tube water heating systems. They make perfect sense for most areas, even work in cloudy conditions and save lots of money. I found out that you will need to have or work with a licensed plumber and probably have to fight over zealot home owner associations in most neighborhoods, but overall it could be a very lucrative business.
e/m
I think the cut out speed is around 50 mph, if I remember correctly. You are right that small wind turbines will automatically turn to the wind, but for the bigger commercial ones they will have to be motor controlled into the wind. State incentives are all over the place and HOA's will have something to say about both solar and definitely wind. Small wind for residential is probably only practical for rural areas where you have a lot of land, andof course you will need battery backup, or grid connection to stay lit when the wind is not blowing ..., e/m.got_nailed said:Yes it?s a vertical axis turbine; thank you. At 300 feet what about the cut out speed of the turbine?...
PV efficiency has hovered around 12 to 15%, and progress has been painfully slow as you pointed out. There are more efficient technologies out there in the labs, but they are a lot costlier and not commercial yet for that reason. I think the concentrated solar thermal electric generation is becoming more and more economical. It generates steam, which is used to turn a turbine to generate the alternating current much like a coal fired plant would. e/m.e57 said:30 years of failed promises of effieciency in the PV end. Thermal like some of the super solar towers and such look promising - as there is not better way to creat electricity than a rotating magnetic field IMO.
Energy-Miser said:PV efficiency has hovered around 12 to 15%, and progress has been painfully slow as you pointed out. There are more efficient technologies out there in the labs, but they are a lot costlier and not commercial yet for that reason. I think the concentrated solar thermal electric generation is becoming more and more economical. It generates steam, which is used to turn a turbine to generate the alternating current much like a coal fired plant would. e/m.
