pvc bending
sparky59
I have a job coming up where i will be running a lot of 3/4" pvc. My question is...can you make bends in it using a regular 1500 watt heat gun and a 1" emt bender?
pvc bending
Yes you can as I have done in the past. Now I just try to use 90''s , 45's, and LB's. I'm just a small company and don''t have use of heat tanks. I use anything according to the NEC and looks neat. Good Luck and Semper Fi P.S. If you use the heat gun be careful and not leave it in one spot to long as you probably know.
pvc bender
pvc bender
they sell these springs you put inside your pvc and you use your pipe bender to make bends just like you would for emt, gal or imc. i have 1/2" - 1" and works pretty good. i used it for schedule 40. schedule 80 i can't speak for.
pvc blanket works good also.
If your going to be doing alot of bends, do yourself a favor and buy a Hot Box...
goes for $389. They also make COLD PVC benders, but I couldn't find the link at this moment...
If you go with a heat gun lay your conduit in a small piece of metal stud. It heats faster and more evenly.
The main thing I don't like about the Viper is that the bends tend to have a smaller radius than factory or field bends, and that can make fish-taping and pulling tougher.
pvc bending
you can use the heat blanket it works very good. heat up your pvc, shape it with your pipe bender , get the bend you want and use a wet rag to cool it off. this method works best on flat surface like a table.
