N844AA
- Los Angeles
In the past if I was running a PVC underground feeder to a structure to feed a surface mounted panel, I would use a rigid elbow and rigid conduit to come out of the ground and feed the panel.
But in reviewing the code, is there any reason I cannot just come up out of the trench and feed the panel with PVC? This is on the exterior of a detached residential garage, the PVC is labeled as sunlight resistant and I do not consider this location to be subject to physical damage.
PVC all the way? Is there a code that says I must transition to rigid?
Thanks in advance!
Thanks in advance!
