PVC conduit in a corner
kornbln
I'm running some 1.25" PVC conduit up a wall in a corner and would like to get the conduit as tight into the corner as possible. What sort of support method could I use to achieve this?
I would go with the one hole strap, that will get you in tighter then the gap created by the fittings or bell end.
Tie wraps and bubble gum :roll:
Really, 1 hole straps are probably the best/only option I can think of that will allow the conduit to be tight to the corner.
Maybe?
mdshunk said:
What if they want to remove it one day ? That would be near impossible once you used the PL glue. Unless you also remove the corner.:grin:
Is this pvc conduit passing thru into the ceiling?? If it is there may be structural things to think about that may cause you issues tight in the corner.
Nope. It's exterior.
My next question - what method do you all prefer for screwing into stucco?
Dennis,
Wood framing... So it's probably stucco, scratch coat, wire mesh, tar paper/vapor barrier. So pretty much just plaster (or whatever it's made out of) is what I have to work with to attach to right?
kornbln said:
Dennis,
Use a long screw and catch the framing, esp. if you are in the corner.
I'm refering more to the part that wont be in the corner... just wide open stucco area
I would try to find the studs. Stucco won't hold much unless their is wood sheathing behind it.
:smile: In which case I would make sure this pipe can expand and contract:smile:
