Jerseydaze
Heres the situation I have .I have a broken coupling on an existing 2"Sch 40 PVC that is surface mounted on the outside of a house is there any pretty way to fix this other then pull out old wiring and pull it back in?
Jerseydaze said:2"Sch 40 PVC that is surface mounted on the outside of a house
Anticipating some problems?infinity said:Even if there was an approved method, how do you plan on getting the old coupling off?
mivey said:Anticipating some problems?
You would certainly have to be careful.infinity said:A broken coupling that's been glued to the conduit would be a problem if you were trying a repair without removing the conductors first. That seems to be what Jersey is trying to do.
peter said:~Peter
Peeetttttteeeeeerrrrr
peter said:Why did it break anyway?
~Peter
blue spark said:Yep, change it out to Sched 80 to make it code compliant.:wink:
Why are you both suggesting using sched. 80? Not every service is subject to damage.peter said:D . . . as suggested, replace with heavier schedule 80.
Well, I did say in my post that I was assuming. However if it's above grade and it's a PVC service, then it's schedule 80. Always has been, always will be.LarryFine said:Why are you both suggesting using sched. 80? Not every service is subject to damage.
blue spark said:However if it's above grade and it's a PVC service, then it's schedule 80. Always has been, always will be.
