ItsHot
- A little piece of heaven!
Anyone know of a pvc repair collar that could be used to repair rnc without removing the conductors from raceway?
Someone here will tell!:-?stickboy1375 said:Dont tell anyone, but I have made a few custom kits with the next larger size conduit and a table saw...
ItsHot said:Someone here will tell!:-?
mdshunk said:Yeah, they have split raceway sections. Not sure the manufacturers of such, but they're available at any decent supply house. The addition of stainless steel band clamps ("radiator clamps") around the spilt repair section is recommended by me. :smile:
repair coupling 1
repair coupling 2
repair coupling 3
repair coupling 4
repair coupling 5
Photos courtesy Tab Faber, Beverton Electric.
Then you got a lot of digging to do. I don't understand the question. Are you eluding to the need for trench shoring?BackInTheHabit said:What if you need to repair PVC in a 4' deep ditch?
mdshunk said:Then you got a lot of digging to do. I don't understand the question. Are you eluding to the need for trench shoring?
Those were plumbers!!mdshunk said:Why would you have to stand in a ditch with little working room? Cause the room you need to be created. If it can't, the job just takes longer. No big deal. I'm not sure about "best way", but these split conduit sections are the only way I know about, other than removing the conductors, putting in real pipe, and pulling back in. I've seen guys wrap some rubber around a broken conduit and pour a burp on concrete on top.
