Jpflex
Electrician big leagues
- Victorville
- Electrician commercial and residential
I haven’t had to go from pvc to metal before so without knowing the proper material hookup for an underground 1’ pvc conduit 12 inches deep trench with 2” concrete to be covering leading to a reduction of a 3/4 EMT to a metal deep 4 square box with 3/4 knockouts for a 20 ampere receptacle circuit
My coworker suggested using a metal 1’ to 3/4’ reducing bushing inside of PVC female adapter at pvc 90 degree stub up bend end to 3/4 set screw EMT connector to EMT and again a 3/4 set screw connector at EMT end to metal box
Would this be a proper way to transition from pvc to emt, we did not have smaller pvc and I never had to go from pvc to metal before? Also a EGC will be ran inside of pvc to mitigate bonding
See picture below thanks
