SceneryDriver
- NJ
- Electrical and Automation Designer
I'm sure your work and Home Depot connectors was the reason for that.
-Hal
SceneryDriver
-Hal
That should do it. If it will be impossible to make any new home runs in the future, run two of each . . . or a conduit.. . . I'm not sure what to run from my data closet to where the incoming service will be I'm thinking just running a cat6 and a coax to cover myself
Are you using this cable for incoming service? I'm doing my house now I ran dual shield all over but I'm not sure what to run from my data closet to where the incoming service will be I'm thinking just running a cat6 and a coax to cover myself
The biggest thing with coax is using RG6 vs. RG95. The former has much higher bandwidth so even CATV is far cleaner. Coax has an upper limit on bandwidth that depends on design and also a characteristic impedance mostly 50 ohms. But since a lot of OTA stuff was originally designed for twin lead that is 75 ohms you see that on older setups. If the impedance does not match in the cable, connector, receiver, etc., you get a reflection which is signal loss. This matters far more than cable length or shielding.
