What is the typical open loop gain for an op-amp? I am using an op-amp as a switch and need the output to be just about the supply voltage (rail voltage) when input is 100uV or higher. My supply voltage is 24 so that means I need open loop gain to be at least 240000. Is this the typical gain of an op amp? I read the datasheet but did not get a clue.
Link to op-amp datasheet: http://www.analog.com/static/imported-files/data_sheets/AD8226.pdf
I appreciate all comments.
Edit: it says max gain is 1000 but I am no sure if it is referring to open loop gain???
