I am looking at a project where the original install shows a freezer 208V and two 120V-20A duplex outlets from a small sub-panel and the panel also has a branch circuit to a outdoor receptacle, when they lose power they plug in a small generator to the receptacle to back-feed the panel to keep the freezer running? my concern is how do you ground a system like this I thought you could not connect a portable generator to a premise wiring system? I did not see a ground rod near the outdoor receptacle but assume you would need something to ground the frame to at least? I will try to get a picture next time I am out there.
