guschash said:Is it permissible to use a abandoned closthes shoot as a raceway, its line with metal. I need to get to the attic and this would be convenent raceway. This is a mutifamily dwelling.
lordofpi said:This is when you send one of your really skinny apprentices in there armed with an NM staple-gun and lots of butter.
it's lined with metal
ceknight said:Permissible or not, I don't recommend it. To me it says "Hack!".
I have seen more than a few laundry chutes converted into raceways, including one in my house (done before I bought it). Every time I see it I cringe and sigh for the lack of craft.
iwire said:I have used an abandoned laundry chute to run phone, cable and feeders from the basement up in a 15 story building.
You'd have to show me that requirement in some model code before I'd agree with that one. An unused laundry chute is abandoned the same as one that is sealed off, since no model code contains the definition of an abandoned space.ceknight said:And if the chute has been truly abandoned, as in sealed off from the habitable space in a house that may not be a candidate for future restoration, then even then I might go for it.
But the ones I've seen weren't so much abandoned as they were just unused. They didn't have the doors sealed off, ...
mdshunk said:You'd have to show me that requirement in some model code before I'd agree with that one..
That is a valid concern, which will be the case whether or not cables are installed in that abandoned chute.DUCKMAN said:My concern is that the chase would cause a chimney effect in the event of a fire. .
ceknight said:But the ones I've seen weren't so much abandoned as they were just unused. They didn't have the doors sealed off, they had sharp metal edges at the basement exit with cable stapled to the joist then unsupported in the chute. If there are kids about who like to play with laundry chutes, then you have an accident waiting to happen. One good yank on that cable and the cable risks losing its magic smoke.
360Youth said:I used to be that guy. :grin:
