If a wire type EGC is run in emt conduit to a metal 4 sq box with a raised cover receptacle or switch , the EGC bonds to the box but does not have to jumper to the receptacles or switches mounted on the cover as long as the receptacle or switch is mounted with (2) screws with nuts and the cover has the indented corners that bolt flat to the box correct?
We talked about this a while back, but I cant find the thread.
Thanks,
JAP>
Thanks,
JAP>
