M. D.
Trevor , If I suspected the circuit breaker I would change it out or swap it with the feeder ocpd and check it at the service equipment, if I wondered about the voltage I could read it through the receptacle for the micro one line at a time or do a continuity test on the feeder cable and read the voltage at the ocpd for the # 6 cable , If there was a concern about voltage drop ,math would work and should have already been considered. Amps could be read at the feeder ocpd as well , visual inspection would not require me to work live.
I'm just reading it like I have never read it before and the words say likely to require me to work it live, I just don't think the trouble shooting likely, would require me to work it live . It might be easier and take less time might cost less too but is it likely to be required??? I don't think so.
There was a thread not too long ago about the law in regard to working live ,I came away thinking that not much I do in residential requires me to work live , when we work live we are exposing ourselves to a high level of risk. I think I could successfully trouble shoot a sub panel feeding a wall oven and a microwave oven without the need to expose myself to the dangers live equipment at the sub panel.
