Rant about 2x4 lay in fixtures....
peter d said:
That's nice, but can you hold a 36 volt drill out sideways with a 1" auger bit and drill through a beam? Larry can. :D
If the bit is sharp and the lead screw ain't toast,yeah!
I'm a Va. boy too!
If I knew how to put a smilie face in here I would. LOL
peter d said:
Well first you need Marc to megger it, then you need Iwire to see if the "luminaire" is code compliant, then you need Larry because only he's tall enough to replace lamps without a ladder, and then you need Marc again to make some witty comment about the whole process, and then you need someone here to make a post about how many guys it takes to change a light bulb, which goes on for 10 pages and then Iwire deletes the whole mess of a thread. :D
I believe I could be usefull here also by confusing the terms GEC and EGC and I could also stand squirrel watch!:D
jrannis said:
Bulbs you plant in the ground. Lamps go in fixtures
Unless you work in the cinema biz.....then it's Xenon bulbs going into the Lamphouse.. :grin: ;)
Edited to add:
__________________
And I would drive most of y'all crazy by griping about your using a MWBC to wire them luminares up... :D
Just start using T-5 lamps and fixtures. There shorter. I have a retro fit kit that fits into a parabolic T8 housing, and turns it into a T-5 fixture. The T-5 sockets and housing fit inside the fixture without even taking the T8 sockets out.
iwire said:
Sorry it may be a 'bulb' shape but I bet it is a 'lamp'. :grin:
You say tomato, I say tamata, yada yada... :)
Like in legitimate (stage) theater, it all depends on who you ask..
