LarryFine
- Henrico County, VA
- Electrical Contractor
The job is yours! :smile:qcroanoke said:I don't know about that... I'm 6'4"
True 'nuff.peter d said:That's nice, but can you hold a 36 volt drill out sideways with a 1" auger bit and drill through a beam? Larry can.
I believe I could be usefull here also by confusing the terms GEC and EGC and I could also stand squirrel watch!peter d said:Well first you need Marc to megger it, then you need Iwire to see if the "luminaire" is code compliant, then you need Larry because only he's tall enough to replace lamps without a ladder, and then you need Marc again to make some witty comment about the whole process, and then you need someone here to make a post about how many guys it takes to change a light bulb, which goes on for 10 pages and then Iwire deletes the whole mess of a thread.
jrannis said:Bulbs you plant in the ground. Lamps go in fixtures
__________________
mxslick said:Unless you work in the cinema biz.....then it's Xenon bulbs going into the Lamphouse.. :grin:
iwire said:Sorry it may be a 'bulb' shape but I bet it is a 'lamp'. :grin:
