Re: RATING OF DISCONNECT 60A FOR FEEDER
Bob:
I think the wording is confusing,but I take it to mean the minimum overcurrent devise to be 60amp.
I guess if you want to install a 60amp disconnect and 60 amp wire, going to a panel, it would be OK to fuse it smaller, but I don't see the point.
This brings up a problem with 225.39(C)
If the rating, does not include the actual size of the fuse, you could put any size smaller than 100amp main in a dwelling.
In any case I would still hold out for the feeder size to the code implied minimums
