Nate Scott
Can you install a receptacle outlet above a grid ceiling and plug in some equipment that has a plenum rated cable into the outlet.I thought the equipment had to be hard wired because the equipment could be removed and then you would have a outlet that would remain there and could be utilized by something else plugged into it that might be a safety hazard.
