James L
- Kansas Cty, Mo, USA
- Electrician
Dennis Alwon[/quote said:Kitchen receptacles are also at 43".
that would center the receps exactly between the countertop and upper cabinet?
For those of you that said they put the measurement to the center of the box, how do you stay consistent with that. Do your boxes have a centerline mark?
I find it easier/faster to make a jig such as a stick or 2x4 and just mark the studs at the top of the stick or just set the box on top and nail it on.
Most boxes, or box brackets have something to find center.
If you use all the same kind of boxes that works good.
But we use various boxes and to end up with a consistent finish you must use the center or a 6/32 screw hole.
To be honest, I've never looked for a center mark.
Now you have forced me into looking tomorrow!![]()
I bet it's pretty close to halfway up from the bottom.Even if nothing marked center I can usually find something.
That must make the Lucky Charms taste kinda funny.Even if nothing marked center I can usually find something.
Keep in mind other than my own home all my boxes are metal.![]()
For a few, I measure. For many, I make a jig like you do. Much faster.I find it easier/faster to make a jig such as a stick or 2x4 and just mark the studs at the top of the stick or just set the box on top and nail it on.
I bet it's pretty close to halfway up from the bottom.![]()
I think this is histerical that there are so many different answers.
I put the recpts at 14" and switches at 48" to the top.
If I'm remodeling I match the existing.
The range and fridge I check the specs. If they don't matter I put range a few inches below the top. I've found that it's easier to unplug them, the higher they are. fridge doesn't matter if there are no specs.
Thanks
Mike
48" to the bottom was standard for switches around here about 30 years ago. Not sure how 43" got started here but I remember using 43" and the architects and designers loved it. I think a customer asked to have them lower. That is pretty much the unspoken rule now.
At 48" the switches often interfered with pictures etc that were hung on the wall so 43" was, IMO a great compromise.
I find it weird/cool/funny when I measure an existing box and its center is exactly on an inch line, like 16 inches. I'm impressed that the electrician probably took into account the measurement from the sub-floor and the depth of the finished floor.
What height off the floor do you guys generally rough in switches,recepts,range,fridge,dishwasher,kitchen countertop etc.....?
Jap?
