What does the situation on the software describe?
This is for service work and it says:
Change one 15A duplex residential grade TR receptacle. Includes cover plate.
This does not apply to new construction or major remodel.
btw, I don't use spools. I use 250' rolls. And I'm not usually moving my stud reels around. I find a good spot that works for the whole house.
What do you use to mount the 250' coils?
How are they not twisted coming off the coils?
I haven't found a 250' roll/coil yet that the NM doesn't come out with loops and twists.
I usually pull off a generous amount and try to straighten it out as I walk back to either cut it off or pull more out.
What sort of parameters are proposed in the software to account for all things not associated with turning the screws?
Is there any sort of minimum or average scope used as a basis? Is that to be added to a trip charge and minimum service fee?
At what point would a service call minimum be overtaken by itemization?
I would think there's not really any practical benefit in estimating time frames for service work items
For example:
Client calls with a receptacle that is broken. You will charge a minimum service call fee to go out and assess the situation. Then decide whether the circuit requires troubleshooting or it needs just a receptacle. Then provide a price for the cost of the labor to change the receptacle and the service call fee.
