Why would he get beat up over that. Everyone knows that is how they should be installed. If they weren't what would happen if the cord was slightly out of the receptacle and a paper clip fell accross the grounded and ungrounded prongs? Oh the humanity!Originally posted by shelco:
GROUNDS UP?
How often do you get beat up over that.
I hate to tell ya that the 3' requirment imposed by some AHJ's is most likly a miss guided atempt to use the requirements of 410.4(D) which only apply to fixtures not receptacles!By infinity: I was just pointing out that maybe the original post had confused the 3' basin rule and with the requirement that the receptacle being outside of the tub and shower area, hence my response.
Also I would add that it doesn't apply to all fixtures. It only applies to the luminaries on the list in 410.4(D), not to wall mounted luminaires that may be above a basin less than 3' from the edge of the tub or shower.I hate to tell ya that the 3' requirment imposed by some AHJ's is most likly a miss guided atempt to use the requirements of 410.4(D) which only apply to fixtures not receptacles!
