surf more
- eastern NC
recess cans blowing bulbs(2 every 2 weeks)---anyone every had problem like this?only happening with 6 lights-4inch direct contact
I would inspect the socket for loose terminals.
There are a couple of older (3 months or so ) threads dealing with defective Halo 5" cans that had a manufacturing defect were the top of the socket shorted against the top of the can, but typically this was when using the lamp extensions.
Using 130 volt bulbs usually solves most of these issues.
guess yall saying if meter reads 120vac -125vac--you should use 130v bulb???50watt indoor floods -120v are the bulbs that keep blowing..i go there this week and i will tell you what i narrowed problem down to.(later in week)
lose terminals produce heatHow would lose terminals contribute to lamp failure? :-?
I have heard this before and personally have felt it is likely a myth.
Loose connections causing archs, which causes rapid heat fluctuations, which causes the element to contract and expand, which breaks the element....I have no basis for this opinion other than personal experience.
BTW, before someone brings up dimmers...dimmers are different because they turn the light off and on soo quickly that the element doesn't change temp.
Still having some doubts that adding any sort of impedance to a incandescent lamp circuit will shorten it's life. :smile:
