tonype
- New Jersey
I see paper around the wires, so I think it is AC cable.
Whoever wired this doesn’t understand that the jacket on AC is the EGC. :lol:
But you can't re-identify a conductor smaller than #8 unless it's a traveler or the white of a 2 conductor cable used for 220, no?
-Hal
I believe he meant volts.220 is load calc.
"220, 221, whatever it takes."
-Hal
Legally, no. Common sense, sure you can.
220 is load calc.
See 200.
Actually it's #4 and larger
I think by "220" he was referring to 220V or what should be called 240V. Like using 10-2 and identifying the white as a hot (ungrounded) conductor.
That's MISTER Mom to you!Yes,mom.![]()
NM also has paper in it. I'm on the "old 3-wire" band wagon, white= neutral, red=egc although they could have either stripped it or taped it green.
NM also has a bare wire. I still think it is AC cable.
One other question on this... is there any problem with the conductor cutting across the panel between the main and other breakers?
Technically no, but it is ugly.
220 is load calc.
See 200.
