- Windsor, CO NEC: 2017
- Service Manager
Re: Red Tagged, 225.39
How can you have one without the other? You can't have a switch without an enclosure.
Look at a definition of consist. The switch contributes to the overall composition we call the "disconnecting means", but it is not the means itself.
So if you have several switches in one enclosure, the overall completed work must be worth 60 amps. I would consider the can the switches or breakers are in to signify that.
My thought is: the reason 225 mirrors 230 is so that a structure supplied by a feeder could be easily converted to having it's own service as time goes by and conditions change.
A snap switch in a garage is not going to even come close. A 3R enclosure outside will come close, provided the NEC artificially increases the installation. Just a thought.
