So I called the inspector today. I had to leave a message with the building clerk and he called back from a restricted number. This is usually a red flag to me. Means he doesn't want anybody to be able to reach him without him knowing who it is and what it's about beforehand. I answer:
Me: Hello?
Him: Is this (My first and last name).
Me: Yes, is this (his first and last name).
Him *slight stammer*: Uh, this is the wire inspector of Sharon.
Yeah, obviously I know who he is if I know his first and last name and am expecting a call. Anyway his position is that the generator salesman needs to have a master license because he's doing wiring for hire, then subbing it out to me. I asked if a workaround could be that he sells the equipment, then "refers" the customer to me and the customer pays me directly. He seemed maybe ok with that.
His issue with the ground wire wasn't even something I installed. Somebody had jumped a #10 from the water pipe to the GEC. I told him I could just remove it because it was redundant.
I did not find anything in the code book prohibiting what I used for support of the SER and he didn't argue after I pointed out that only cable ties are required to be listed for cable support.
His response to the unistrut was that he had no way of knowing that I drove it deep enough into the ground and that I should have poured concrete.
As for the SPD, his position is that I "replaced" the main breaker by installing equipment that became the main breaker.
I could see where he was coming from although I disagreed. He kept trying to make the phone call adversarial and I kept trying to make the call cooperative between two professionals.
Eventually he says he's going to call the salesman and asks for his number. I say, "It's on the picture you took of his yard sign". He asks his name, I tell him.
He never called.
