liquidtite
- Ny
I recently switched companies that I work for so I coudnt see the end result,the last job that I was on was in a hospital were we had redundant grounding.I was woundering when you bring your redundant grounding conductor to the panel it has to be on a ground bar that's not bonded to the pane?.And if so what makes it a ground do you have to get a ground from a seperatly derived system or transformer.Or are the two egc,s bonded together in the panel?
