north star
- inside Area 51
renosteinke,
You are not the norm or typical electrical component
user........I would venture to say that "the masses" aren't
too concerned with placement of receptacles, switches,
etc. either, hence, the codes only meets the minimum.
While doing your remodel, as long as you meet the
minimum requirements, you're good!
If the "rules" did not exist, as has been in the past,
...anyone could do what they want, and anarchy would
ensue, ...again!.......Also, if you [ or others ] build
something in a location NOT to the minimums, and
for some reason you move away from that location,
the AHJ is stuck with what has been constructed.
The codes; while they seem to be a lot of minutia, have
developed for a reason......Unfortunately, they do not
cover every single aspect of what every individual
wants or desires for their living conditions........No
disrespect to you, but in a lot of areas around this
planet, the minimums are not being met, and peoples
lives change, ...sometimes rather quickly.
renosteinke,
