wirenut25 said:Does anyone use a dedicated HR for a fridge?
LawnGuyLandSparky said:15 amp or 20 amp?
brantmacga said:i have dedicated fridge, microwave, and dw lines.
peter d said:.
The dishwasher and disposal will both go on one 15.
Cavie said:You might want to rethink that one. Final inspection is no time to have to run a circuit to that location.
480sparky said:I always do the 2 SABCs, plus dedicated 20s for the fridge, micro, dishwasher & disposal & dining room. Lighting is always seperate.
480sparky said:I always do ... dedicated 20s for the fridge,...
bkludecke said:That's how we do it also. BTW this is a minimum for us. In the big kitchens we may have a couple more SABCs + other circuits for the warming drawers, veggy frig, wine refer, etc......
celtic said:Why?
What type fridges require a 20A line?
Lots of 11 amp dishwahsers around here. Doesn't leave much for a disposol. Ad 'em up and poof!peter d said:Why? Are you saying that this installation should fail an inspection?
I've already put plenty of thought, as well as actual installation experience into this. Let's look at the logic here.
Dishes get "pre-cleaned" first. Stuff gets scraped off and into the disposal. The disposal runs for a few seconds. Dishwasher gets loaded then turned on.
Where is the problem?
celtic said:Why?
This batch of Sub-Zero's you speak of must be new...newer than 06-24-2007...bkludecke said:Big ones. Out here the large custom homes have 2-3 of 'em. Sub Zeros with a 5-20 cord cap and 20amp circuit requirement. After you add the circuits on a couple of new homes you start puttin' 'em in at rough to cover your a**.
#7 from Refridgerator - seperate circuit?celtic said:Awhile back this question came up here ~ 20A vs. 15A for the refridge (or something similar). I checked just about ALL the install pdf.s at the sub-zero site....not one required/recommended/suggested a 20A line - but rather a 15A.
So why use a 20A?
