MikeGee
- Baltimore, MD
I use a husky LED head lamp and a helper holding a flash light.
MikeGee said:I use a husky LED head lamp and a helper holding a flash light.
...a helper holding a flash light...
celtic said:It would be more cost efficient to buy the most expensive battery operated light known to man
mdshunk said:That would be this one. 900 bucks for battery version, 1200 bucks for rechargable: http://www.foxfury.com/products/mf_1000_series/index.htm
Best laugh I've had all day. In all seriousness, they're getting cheaper and cheaper. My oldest son gets these catalogs that have Russian surplus night vision stuff for not too much money.peter d said:I use night vision goggles.
I don't think that the sander guys would want to change fuses.:smile:wireguru said:with a fuse??? you could sell those to the floor sander guys
Bob just uses The Force. Myself, I still need training wheels, so to speak. I install braille wire and breakers.iwire said:You guys all still need to see?
What a bunch of newbies.![]()
mdshunk said:Bob just uses The Force. Myself, I still need training wheels, so to speak. I install braille wire and breakers.
Yeah, pretty much. Basement stairs are real tough for me, being that I can't see at all.Bernard1599 said:I?m new here and don?t mean to offend, but is this what is meant by saying ?The blind leading the blind??
Regards,
I wouldn't want the risk of making tool cases hot because the neutral clip popped off of whatever it was clipped to, which is what would happen if I used a 3-wire cable.lucky1974 said:I also am an alligator clipper. Larry am i understanding that you have 4 seperate alligator clips.Wouldn't the ground and neutral under one clip be sufficient. Sorry just don't understand what seperating them ,and then attaching them to the neutral anyway would do for you.
And, of course, you can gell black from white just by feel, right? :grin:iwire said:You guys all still need to see?
ditto, ditto, & ditto...:roll:SEO said:I'm finding that the older I get the more light I need and sometimes I still don't see the light.:smile:
