Yes, just as improperly failing something does not make it non-compliant.
I am just saying if you go 100% by code you will find a violation almost every time on any given job, no matter who did the work
“ shoot low boys their riding shetland ponies”
I disagree, for those who know the code and install per the code their installations will be 100% code complaint. It's the guys who don't know the code who install violations everyday.I am just saying if you go 100% by code you will find a violation almost every time on any given job, no matter who did the work
Wow! really? "it's not compliant,,,,BUT,,,,"Trevor we don't install outdoor panels except as a main disconnect. This was an old method many used, I did also, but the only time it is an issue for us is when we change a service that was done this way.
Imo, putting 2- 2" pvc connectors or couplings is the best install for these panels although it is not compliant.
It has been done all over the country and I have never heard of an issue with the install.
You might be right maybe they have information that will say that it's unsafe but if you look at the photo #2 in post #15 what could possible go wrong with that installation which would make it a hazard?Wow! really? "it's not compliant,,,,BUT,,,,"
have you stopped to consider 2 things, Maybe the CMP has access to statistics of failures that you may not see and do you go to all the buildings that have had fires to see what does and doesn't work?
That is a slippery slope to step onto. If we apply all code requirements to the barometer of "what could go wrong?" we are limiting the installation to our own experience and not the requirements of the code. While I do not always understand why a specific requirement is in the code, that does not mean it is not enforceable or without reason.You might be right maybe they have information that will say that it's unsafe but if you look at the photo #2 in post #15 what could possible go wrong with that installation which would make it a hazard?![]()
You said "between the studs" that would be prohibited using the 18" of raceway since the panel is not surface mounted.Let’s just say you are installing a 60 space panel in a new house and it between the studs. How are you going to get 50 or so NM in their?
And if you can use a 18” nipple, why not a just MTA?
There is no real difference (other than the box is 8" max and the panel 12" max). IMO either one is safe but according to the NEC one is allowed and the other is not.So, why then do we do we not have to secure the NM to a plastic outlet box? What is the real difference between that and the NM going to a Mateo box( panel)? If it is true for one shouldn’t it be true for the other?
For me if I'm inspecting a job and the photo in post #15 is what I see on the job-site the installer will be ripping it out and doing it correctly according to the NEC.
I agree because there is no reason to do this other than laziness. One can get into the top and bottom of the panel and you can use 2 nm cables per connector. No reason to not do it correctly
I would say it not knowing any better.
If someone would say “the rule is in there because of this reason” that would help some of us learn how to do thing right and “to code”
Whoever taught you this method was saving time and trying to avoid taking the right path. You yourself may not have known but surely your bosses knew.
Maybe laziness wasn't the best word but I can think of other words that aren't much better...LOL
