kwired
Electron manager
- NE Nebraska
- EC
I'd rather you randomly select which ones you wish to look at. If connections are made up at rough in do you look into every outlet box or just randomly look into only a few of them and if you find no problems assume they knew what they were doing on the rest?With me it's simple, and more so with metal boxes than plastic, but you are required to bond your boxes. If at rough you have decided not to make up your wires then that's fine and you can open all of the boxes and light fixtures so that we can verify that you have done so. If it's done at rough, then I don't have to open near as many boxes to check that they are done correctly.
I have no problem with which method you use, but then you don't get to have a problem with which method I use to inspect it.
If I am intentionally doing something wrong - you just may pick one that is wrong. It is more likely I am doing the same thing in every box, and if you randomly look at a few of them and find nothing wrong - there is a good chance they are all the same.
Why do inspectors feel they need to see absolutely everything - as if they don't trust the installer? Non licensed installers or licensed installers that are repeat violators I can understand being a little more cautious with.
I might miss bonding a box sometimes. If you catch it thanks for the help. If you don't catch it we both failed didn't we?
