ivsenroute
- Florida
Let us forget for a moment that this particular main disconnect is in a crawlspace and focus on the actual issues inside the main disconnect. The bare copper is for the GEC as you probably already assumed. We do not connect the GEC to the meter base enclosure in this area so that will not be an issue either.
This comes from a 200A OH service and this disco goes to the main panel subfeed.
This is what I found and after we get some comments I will explain what was done by the "electrician" to fix it.
What violations do you see under the 2005 NEC?
