RHJohnson said:When all is done, I want to see the client, homeowner, or whoever. to be
happy with the workmanship, and the price he paid. If, and that is a hugh IF, he does not realize the quality of what he got, for what he paid for, I'd just tell him to stop at a few jobsites and see what the work at those locations look like. The result of this quality work is a customer for life!
splinetto said:Im going to ask my insp if he would fail my house if I pulled 3 wires in one hole, pulled wires diaginal, drilled holes un even and only used one staple at every box...Ill let you know what he says....
stickboy1375 said:just my 2 cents on the subject, the ONLY reason I dill my holes in a straight line, is for ease of installation, I feel I can pull wire twice as fast pulling it straight, then trying to pull at all sorts of angles, and i'm sure my efficiency at pulling wire makes up any cost difference for extra material I may have used....
splinetto said:Then why isnt compliant OK for exposed work??
tallguy said:For the same reason that a plumber wouldn't use PEX:
in a period bathroom:
LawnGuyLandSparky said:All it's missing is a little exposed K&T!
480sparky said:Or a period-era receptacle fed from a GFI in another bath
tallguy said:With a "GFCI Protected" sticker, right? :grin:
As my local inspector says, "nobody enforces that".
480sparky said:Enforces what?
splinetto said:The one hole for multiple wire topic got me thinking at work.(And Im apparently the only one on here that does that). Why do I run my wires horizontal and vertical with the framing members? It would be much faster to just pull them diaginal if need be. Not saying that I would even do it But does anyone here do it that way?
gndrod said:Hi Splinetto,
Ran across this fine subject of wiring across town and for those who call it spider webbing may date themselves like I am doing. Yeh, I used to do diagonals until the GC told me to follow the grid or don't expect to get anymore work from him. He gave some good reasons that affected his schedule and complaints that slowed down the HVAC and insulation subs.
Even the plumbers who didn't get in their rough before I got there got miffed in bathroom crosstowns that got in their way. A couple of cut or banjo strung cables caused by other trade materials sent a message once or twice when the AHJ tagged the wiring.
Sure I saved a couple of feet but at the expense of losing jobs I got straightened out in a hurry. The transition from factory boy to residential is a big difference in every sense of how rope is pulled to how an AHJ can interprete code to send a message. Diagonal spiderwebbing can be a violation [334.30] and is not acceptable to many AHJ inspectors. Wiring requires protection [300.4] from in-wall physical damage that occurs from other trades trying to jamb their equipment into stud bays and joisting that has cross-town wiring.
Following the structure grid is a professional courtesy to other trades that depend on a strict stayout rule awareness and the speed to get jobs done on schedule. I used to think an electrician was the center of the universe until I got job training on paying attention to the overall picture and getting a consistent paycheck from the man. Sure there are occasional areas where a diagonal is needed, but in the long run (pardon the pun) I do not advise it from anyone in the industry. I hope this might help from a long time point of view. rbj
bikeindy said:We never rough before the other trades, it makes little to no sense to do that there are always ways for us to get wires where they need to go HVAC and Plumbing is a much different animal.
