Also, if the same frame extended upwards to form the superstructure, but the superstructure were made of a different metal such as regular iron (which is weathering steel for the base-model option nowadays AFAIK), would the NEC 2020 still consider the superstructure to be both a grounding electrode and a grounding electrode conductor? If not, what would the NEC 2020 consider it to be? Also, would this superstructure be allowed to be used in essence as an EGC under the same conditions as the substructure besides being above-ground?
