zappy said:I was at the store and the rg-6 was the cheapest. Then the rg-6 quad shield.Then the rg-59 was the most expensive.Don't know which one to get for my installs.Thank you.
wireguru said:RG-59 is what used to be used for TV, but it doesnt accomodate the higher frequencies in use today and is no longer used for CATV / Sat. It is however still used in baseband video applications such as CCTV, this is often of a different construction than typical RG-59 where it uses a copper braid instead of foil/aluminum.
RG-6 is the standard for all television applications
RG-6 quad used to be used by the cable companies many years ago. They all use RG-6 now.
There is also RG-6 tri shield which has one extra layer of foil over the braid, but it isnt very common.
The main thing is make sure you purchase quality cable. The general cable brand stuff at the home improvement stores is junk. Also, dont buy anything in a pull out box. it kinks and causes signal problems. always use coax off of a spool.
The best brands are Times Fiber, Commscope, Belden. I have also had good luck with chinese cable sold by North American Cable Equipment
Make sure you use a proper coax stripper and dont nick the center conductor when you strip it. If you nick the center conductor, this causes problems with the signal as the signal is actually a wave that rides on the outside of the center conductor.
Use compression style fittings. Dont use crimp on or twist on type.
That may be from the cutter you use. A typical cable cutter pinches the center conductor flat when it's cut, so the tip is no longer round.kornbln said:I've had trouble getting compression fittings (Snap-N-Seal) to slide over the center conductor proplerly because of inconsistant diameter.
LarryFine said:That may be from the cutter you use. A typical cable cutter pinches the center conductor flat when it's cut, so the tip is no longer round. I used to have the same problem with the Belden 1505 I usually use.
The curved-jaw type of cutter does not leave the wire flattened:
LarryFine said:The performance difference bewteen cable types is the rated signal loss in decibels per 1000 feet and nominal impedance. RG-6 is better than RG-59, RG-11 is better than RG-6.
Quad-shield cable is highly overrated and is unnecessary in most installations. Most cable-company runs, especially underground, are shielded with less-than 100%-coverage braid.
RG-6, a 75-ohm cable, is used for virtually all RF (radio and TV) applications. It usually has a copper-clad steel inner conductor, and aluminum braid and aluminized mylar foil shielding.
RG-59, a 50-ohm cable which is usually all copper, is ideal for audio and video applications. It solder-able, thinner and more flexible, and easier to terminate, especially with RCA plugs.
Added: In my AV system, the only RG-6 I have is from the DTV dish to the multi-switch, and from there to the individual tuners. Everything else is RG-59 for the reasons stated above.
You are absolutely correct. Thanx.wireguru said:RG-59 is a 75-ohm cable as well.
hbiss said:As far as I can tell, the only Snap-N-Seal connectors that call for a specific cable are the head-end F/BNC type.
Another aspect is the difference between different manufacturers compression connectors. Some are longer than others and you will need to use the correct tool for the connector you have. All tools are not the same and all connectors cannot use the same tool.
-Hal
