A/A Fuel GTX
- WI & AZ
- Electrician
What about transitioning from MC to EMT? I've seen this done by the same method, MC connector srewed into a GRC coupling, EMT connector srewed into the other end of the coupling. MC stripped and wires fed through the EMT to termination point. I've seen this done in steel buildings where MC is run throughout the attic area and EMT is surface mounted down the walls to receptacles. Would that be a violation?
