If you want to place a large enough order you probably can get about anything you want, including your company name and contact information printed on it.
My money is if you order 14 with a yellow jacket, the manufacturers will refuse to make it.
Lets spend your money to find outMy money is if you order 14 with a yellow jacket, the manufacturers will refuse to make it.
Lets spend your money to find out![]()
Whose knuckles are closer to the ground?I dunno... I get those two mixed up all the time. One's the bookie and the other's the muscle.
So does marking it with yellow tape.Yes painting all that 14 does get tedious
Even the manufacturer's in China?My money is if you order 14 with a yellow jacket, the manufacturers will refuse to make it.
I'm more industrial & commercial. But, I am trying things on my own now. Anyway, I've still seen my share of Romex, but black 12/2 w/#16G? I have never seen anything like that before.
The homeowner wants me to use it. But, I didn't notice it til today. I know code says 90° Celcius, but is ok to use. Which I'm not going to now either way. someone's buying some wire. Probably me.
Back in the day each mfg color coded to there own liking, some not to indicate wire size but more as mfg branding. I've pulled a lot of that black cable that was 12/2, 12/3, 14/2, and 14/3. Some cables even had green insulation on ground conductor. That undersized ground dates back to the first grounded cloth sheath cables and carried over to the early plastic sheath product.I'm more industrial & commercial. But, I am trying things on my own now. Anyway, I've still seen my share of Romex, but black 12/2 w/#16G? I have never seen anything like that before.
If it has reduced size bare, probably from the 60's. Much older than that there likely wouldn't be a bare conductor at all.I'm more industrial & commercial. But, I am trying things on my own now. Anyway, I've still seen my share of Romex, but black 12/2 w/#16G? I have never seen anything like that before.
I started wiring in 1992 and we were still getting black-sheathed 14, 12, &10 for at least a year or two after that. Especialy 3-wire.If it has reduced size bare, probably from the 60's. Much older than that there likely wouldn't be a bare conductor at all.
Otherwise black sheath on 14-10 AWG cables seemed to disappear altogether by mid 80's.
Fabric sheathing that is black, or plastic sheathing that is black?I started wiring in 1992 and we were still getting black-sheathed 14, 12, &10 for at least a year or two after that. Especialy 3-wire.
Neoprene I thinkFabric sheathing that is black, or plastic sheathing that is black?
