peter d
- New England
What's the deal with the ballast disconnect in the panel???
those ballast disconnects are only rated for 3 amps.
what the heck are you guys talking about, this is a romex thread not a ballast question.
Peter,
This was a DIY, no telling what the guy had in mind.
What the heck are you talking about? The OP posted a pic of a ballast disconnect inside of a panel.
It fits well with the equipment ground connection![]()
appears to be connected by the panel mounting screw and looped counter-clockwise....
if there's a short the ballast disconnect will probably melt before the ground fails![]()
Peter,
hmm, maybe he saw them at homedepot and thought they were 2 pole wagos. They come already plugged together in the package.....
i am curious, if you were to pull that romex out of the conduit, if there is an inline splice with another one. The romex is yellow going into the pipe, what color is it where it comes out?![]()
... egc connection ...
Can Romex EVER be run inside of a conduit?
You can muddy it up and add all kinds of things to the question, but the answer remains yes.
