- Simi Valley, CA
If we were to stop posting opinions this would be an awfully quiet place.
You know what they say, opinions are like farts, nobody want's to hear mine.
Do you think the duct excceds 90C (194F), I sure don't think so.:smile:
even if that's why he WANTED it to be done that way doesn't mean that he gets to make up the codes as he sees fit. Bottom line is it's not a code and he's just a MORON.Perhaps this has nothing to do with heat. Obviously it is not a NEC violation. Maybe the inspector was thinking safety. Not too long ago a thread reveled that a poor appliance installer was electrocuted installing a dryer. Seems that a nicked conductor energized the metal studs. The vent pipe became energized as well. When the guy went to connect the vent he completed the circuit. Maybe that is why the inspector wanted the cable and pipe to have some spacing......I'm just sayin'
The inspector is definitely wrong. So it's not way too quick for me too say what I said.
Is there a full moon tonight??I will remember that next time you say an EC has done wrong.
How's that a poor installation practice? Sounds like all in favor of keeping the romex off the duct are most likely commercial guys who upon taking a stab in the dark would imagine that it's a good idea to keep romex off the duct and probably a code.The inspector may or may not have been wrong I have in my personal experience been called to troubleshoot houses where the nm shorted to the top of hvac dryer fartfan ductwork due to the vibration. How hard would it be to clear the cheesey nm to prevent some poor unsuspecting service guy from getting electrocuted in a crawlspace from a duct that has become energized due to poor instalation practices????
I think that I do contribute something to this forum every once in a while, perhaps more. But it has been awhile since I've let loose so just relax.steelersman,
It would be nice to see you contribute something constructive in this Fourm once in a
while, instead of just finding ways to be rude. JMO.
It's obvious from the OP that the inspector had an issue with the multiple NM cables simply touching the dryer vent duct, not with the cables being stretched out or stressed. He is plain and simply wrong. Accept it and move on or provide the code article.My comment was, that we cannot judge a call that may be a judgement call. Sometimes the poster of the thread does not give all of the details of what actually happened on his/her job.
When the HVAC installer "pushed" the NM cable up to get it out of his way, a couple of things may/could have occured.
1. He could have damaged the NM cable as he installed his duct work. I do not know of HVAC workers who install plastic duct, so I would think this is metal duct work.
2. As he pushed up the duct work, the NM cable, as it passed thru the holes drilled in the beam may have been stressed beyond their limit - depends on where the holes are in relation to how far up the duct work pushed the cable.
So, without seeing details such as this, it is hard for us to judge from the computer screen to see just what this inspector saw, with so little info from the OP.
As an inspector, when I see other trades have damaged installations, or created a violation of the EC's installation, I always give the EC an option to fix it or I write a violation to the property owner. There are times the EC will ask for a violation to be written, so he can use that for a backcharge. There are times the EC will just fix the issue.
but 90.4 is avalable however I would never site it
the only one that you could rightfully possibly site and get away with it would be 90.4. The others have nothing to do with this situation and make it look like a feeble attempt at reaching out for something that just isn't there IMO.How about 110.12, 300.4, 310.10, 310.15 without seeing installation it would be impossible to call but 90.4 is avalable however I would never site it. An inspector has to use his judgment and make the call as he see's it. He may be right or wrong but he puts his name on the inspection report and most inspectors have made a mistake now and then they are human.
The inspector said the romex could not tough the dryer vent pipe. Is this a code violation?
Thanks
