mbrooke
Batteries Included
- United States
- Technician
Do they still make romex without ground? Or something that is at least similar to it?
I know someone does, cuz central vacuum installers use it.
It is not. Cordage wouldn't be legal.Are you sure its not just SJW or SOOW cord?
Central VAC cable is typically only rated for 24V. It indeed is two conductors (no ground) only but usually fairly small gauge (I've never seen more than 16g). They also make similar cables for installation of low voltage lighting.
Can you use tray cable for your application?
We've bought 14 gauge for low voltage lighting. I bet someone makes a 12 similar.
SPT cable?
Southwire catalogs 14-2 without ground in UF. Similar enough?Do they still make romex without ground? Or something that is at least similar to it?...........
I doubt it.Does the NEC allow that in wall?
I doubt it.
Here's some class 2 cable that's sold as speaker cable. In-wall rated
