Epalmateer
- Michigan
- Electrician
Out of curiosity, what height is everyone's standard on a rough for bathroom vanity lights, kitchen countertop receps, general wall receps, and switch boxes?
48” center of light switch, 18” center of general wall outlets.Out of curiosity, what height is everyone's standard on a rough for bathroom vanity lights, kitchen countertop receps, general wall receps, and switch boxes?
I always put switch boxs @ 48½ to top. This seems to make sense as drywall breaks @ 48½" mostly. Just 2 cents from an old hand.Out of curiosity, what height is everyone's standard on a rough for bathroom vanity lights, kitchen countertop receps, general wall receps, and switch boxes?
NEC doesn't care on receptacle height, other than 5.5 feet maximum to be considered a required receptacle per most 210.52 covered receptacles.Been recently told related to ADA there is push for minimum receptacle height of 2 ft even in residential applications and for all new and renovations. Sounds as if it might actually get into the regs. Not sure if it is just a state thing or NEC.
If you make up a jig to use for mounting those receptacle boxes it shouldn't matter who is mounting them, they should all be same height.Here it's all over the place. I measure to the top of the box. Never center, never bottom.
When I mark out, I use a 4-ft ruler and mark every switch counter receptacle at 48 to top.
Receptacles get marked at 14" but lots of guys go hammer height to bottom. I don't care so much about that. I just make sure only one person is nailing up receptacle boxes on each floor so they do them all the same on that floor
I seem to always be using different help, so I just make sure everyone is doing the same things
Had some help once, two guys, one put the bottom of the box on the mark, the other put center of box on mark. OMG I didn't notice until we had everything made up.
When I first learned 30 years ago, we put kitchen counter receptacles at 44 to top. Then we put vanity receptacles at 46 to top
But anymore it seems most vanities are 36 so we just started making sense to put all those receptacles at the same height as the switches
Vanity flights I used to put at 82 to center but with the taller vanities now I put them at 86
Since walls typically get 1/2 wall covering, make the jig out of 1/2 plywood, then you also have built in depth setting on the jig, just hold the front of box even with the face of jig.
Receptacles are ugly so the lower the better so for me 15". Switches 45".
These are pretty https://www.legrand.us/wiring-devic...utm_term=4586887638851168&utm_content=OutletsReceptacles are ugly so the lower the better so for me 15". Switches 45".
