PowerSupportElec
- Ny
I know that the best answer is not to run conduit outside of the house, to fish it in the walls instead. But sometimes that just won't work, or the customer doesn't want it.
I have to add a new receptacle in the outside wall of a second story room for a window air conditioner. The attic space is completely close off and the customer doesn't want any walls cut. THe easiest way to do this is to come out of the basement through the rim joist, LB a 1/2 raceway upwards, then LB back into the house right behind the new single gang box that I cut in.
THe problem with this is that it could be a bit difficult to get the pipe cut the correct length to match up with the new-work box cut into the wall. Even if I bring a helper with me to work outside while I am inside, it's still a pain.
I was wondering if anyone had any tips for this situation? This is getting inspected so it has to be code compliant.
I was thinking about installing UF in the raceway instead of THWN. This would allow me to come out of the LB at the top and free-air the UF into the box. Any concerns with doing that? Any other tips or tricks?
