Sat. pics
ceb58
Raeford, NC
Here's one I have been involved with this week. Lightning strike caused an arc in the 1000amp switch gear which in turn set a battery bank on fire. The ground fault also arced on the gen. set next to the lower radiator house causing a hole in the hose.The 500kw Gen. set cranked but ran hot causing the piston to come through the side.
Fun stuff. That in Concord? I had some calls for replacement breakers with a similar story friday.
