mbrooke
Batteries Included
- United States
- Technician
Understood. If you must start from scratch, a relay will give you the most protection from arc flash. However, you must perform a short-circuit and arc flash study in accordance with IEEE guidelines to determine how to set the relay. A relay will also allow you to have a maintenance setting that can be enabled when personnel are working on live parts. This setting will push the relay's trip curve as low as possible to pick up a fault almost instantaneously.
Remember, time is your enemy. Incident energy is a variable created by the power industry, not physicists or mathematicians. You need to think more like a specifying engineer to solve this problem. An academic approach will not provide a real world solution to mitigate arc flash at a meter can.
I am not sure what other methods exist to decrease arc flash energy. At the end of the day, you can only control how fast a protective device opens. Messing around with air gap distances, materials, ppe, etc. only slightly mitigate an arc flash that will always be present when two conductive bodies are separated.
Relay? Why not a current limiting fuse?
