electricmason86
- rochester, mn
Is there a difference between a vertical and a horizontal seal off, or can any seal off meet the requirements
Check out Crouse Hinds “Chico”Which sealing compound product would you guys recommend be used? For my application, the wires need to be sealed coming out of a temperature class H generator enclosure (~155degC-180degC) in a class 1, div 1 location, groups B, C and D. The seal is supposed to be a “setting” compound I believe, just not sure what to use.
You are required to use the sealing compound that the seal fitting was listed to be used with. It is part of the listing of the seal fitting.Which sealing compound product would you guys recommend be used? For my application, the wires need to be sealed coming out of a temperature class H generator enclosure (~155degC-180degC) in a class 1, div 1 location, groups B, C and D. The seal is supposed to be a “setting” compound I believe, just not sure what to use.
The generator design is in the development and prototype stage at the moment, and enclosure has not been submitted for approvals yet (and the wires have to be sealed where they pass the wall of the enclosure). I am trying to select a specific epoxy that will make it past approvals for a temp class H motor/generator and want to do something similar to this photo:You are required to use the sealing compound that the seal fitting was listed to be used with. It is part of the listing of the seal fitting.
