hamzazayyad
- jordan
Hi,
I would like to know if the sealing fitting is required in the following cases:-
1- the motor is explosion proof but is has internal switch(thermostat switch) !!!!
2- the switch(pressure switch) is certified as explosion proof switch but these is no label on the switch to indicate that it is factory sealed switch !!!
3- do we need to add sealing fitting to the terminal box(junction box that has only terminasl to connect the wires) ???(that does not has make and break or high temp ??
Thanks..
Thanks..
